Discovery Import
Discovery Import
SpaceClaim and KeyShot 9
    • informatica
      We updated the SpaceClaim version, to the last version 2020 R1.
      We need use the KeyShot 9, but with the 2020 R1 version of the SpaceClaim, the KeyShot is the 8.2.
      When can we use the KeyShot 9 with SpaceClaim?
      Thanks
    • Charudatta Bandgar
      Hello Synersight User ,
      Can you please follow the steps mentioned in this post? Let me know if it works for you.
      Regards
    • informatica
      Hi!
      I have followed the steps in the manual and it still doesn't work, I am detected by KeyShot 8.2 not KeyShot 9
        Can you please send a snapshot of the properties panel with the modified 'target' field as mentioned in the solution pdf (refer image for reference)?
    • informatica
      "C:Program FilesANSYS Incv201SCDMSpaceClaim.exe" /UseLicenseMode=true /incubator="Use Newest KeyShot"
        This generally shouldn't be the case. I will talk to my teammates and find out what might be the issue and will get back to you soon.
        Regards.
      The steps I had suggested works for every version of KeyShot except for KeyShot 9. KeyShot 9 is not yet not supported by the 2020 R1 version of SpaceClaim, and this issue will be sorted in the next version of SpaceClaim.
      Sorry for the incorrect initial assessment of the query and sorry for the inconvenience.
    • informatica
      Thank you very much for your help, we will wait for the new version in order to test KeyShot 9
Viewing 5 reply threads
