Discovery Import
Discovery Import
SpaceClaim anf import error
    • yoonho.kim
      A customer is trying to use anf file for PCB Mechanical analysis.
      While importing anf, SpaceClaim shows following error.
      I tested other several anf files but same result.
      Is there any known issue regardigng this?
      I attached simple anf example.
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
    • Naresh Patre
      Hello yoonho kim
      I was able to import the file in Discovery SpaceClaim 2019 R2. See below snapshot of imported geometry. Are you using Discovery SpaceClaim or Standalone SpaceClaim? I guess the latter one doesn't import anf file.
