June 30, 2019 at 2:08 am
omarfarid
SubscriberHello,
I want to increase the number of core when I using the SpaceClaim. I'm using a large number of bodies and it hard to use only one core, specially when my Computer has about 28 core.
Please let me know if you have anyway to help with that.
Thanks,
July 1, 2019 at 2:59 pm
Ansys EmployeeCAD typically only works on a single core. Turning bodies off usually helps, as it's usually the graphics rendering that slows things down.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3778
2573
1825
1242
598
