November 29, 2022 at 12:36 pm
TSELA MPELINT
SubscriberHello, I am trying to do an STL file to solid to run it on fluent. I have done these steps 1) add thickness of 4mm 2) shrinkwrap of 1mm everything until here is fine. But when I go to tools and press auto skin, I select my body and I wait a few minutes and Spaceclaim closes. My model is an aneurysm and I am doing my thesis so if anyone can help will be great. I am using ansys 2022 R2 student
November 30, 2022 at 4:02 am
Keyur Kanade
Ansys EmployeeYou can use manual approach. Auto skin will work if shape is very nicely defined. Otherwise you can use manual approach.
You can convert faceted data to solid in SpaceClaim. There are different ways to convert stl to solid.
The first one is using Right Click on the body in the structure tree and select Convert to solid option. This option is useful for planner surfaces and simple bodies. If your body has some fillets or curved surfaces, this option should not be used.The other option is using Skin tool. You can find more information about Skin tool in help manual at following link.In SpaceClaim different commands can be used to create solids from faceted data. Various options are shown in following video.Whether you need a rough or accurate construction of a model, or tooling based on mesh-scanned data, Discovery SpaceClaim's easy-to-use reverse engineering tools will autosurface any STL data to get your job done faster. Learn more: https://www.ansys.com/discoverywww.youtube.comPlease go through help manual for more details
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2656
2120
1347
1118
461
