Discovery Import
Discovery Import
SpaceClaim – different behavior of an allignment
    • l.janicek
      🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
      Hello, could you help me with the described behavior bellow?
      When I have "Enable constraint based sketching" the alignment works different than when I have the function "Enable constraint based sketching"  turned off.
      Turned on "Enable constraint based sketching" - always aligned to the X axis
      Turned off "Enable constraint based sketching" - alignment to the nearest axis
      You can see the behavior in the attached video.
      I would like to use "Enable constraint based sketching" with the alignment to the nearest axis.
      Thank you.
      Regards, Lukas
    • Naresh Patre
      Hello Lukas
      I am able to reproduce this behavior and have submitted BUG 444839 so that the development team can look into it.
      • l.janicek
        Hello Naresh Patre
        I forgot to add, that in the 3d mode it works similarly strangely.
        Thank you, Lukas
    • Naresh Patre
      Hello Lukas
      The development team said that this behavior is expected. They said that it could be possible to add a toggle option to switch the behavior. So I requested them to take this request as an enhancement.
