Discovery Import
Discovery Import
SpaceClaim does not find file paths
    • rg
      Hi, it often happens that in spacecliam when I go to make file open does not see me the folders on the server how come?
      If I open those folders from computer resources or other programs, it sees them
    • Brian Bueno
      Roberto
      Have you added the file paths to the list in SpaceClaim Options > Support Files?  Perhaps that will help.
      The problem might also be related to your network, or the availability of the PCs in question.
      • rg
        Brian Bueno Hi Brian, can't I add the path from SpaceClaim settings as it doesn't see what it can be?
    • rg
      Only SpaceClaim fails to access the other programs accessing the network
    • Brian Bueno
      Roberto
      So it never finds the folders?  What if you manually type the file path into Windows Explorer when using File > Open?  Something like \Server_Name.  Does it find the server?  Might it be related to permissions?  What happens if you launch SpaceClaim using Run as Administrator?
      • rg
        Brian Bueno Hi Brian, now I'll try to do what you told me and I'll let you know
    • rg
      Brian Bueno Hi, I haven't heard anything from the customer I think we've solved.
      If there will be news in the future I will let you know
      • rg
        Brian Bueno Hi Brian now everything works
Viewing 4 reply threads
