October 20, 2023 at 8:00 am
Jean COLLOMB
SubscriberHi,
I have a geometry with multiple holes for bolt.
I would like to fill holes and add hardpoints in order to create joints in Mechanical. The fill function is not a problem, but adding hardpoint is.
Is there any function to do that ?
(I tried to create point in a sketch, print the face with it, but the point disapears in Mechanical)
Thanks a lot,
Jean
October 20, 2023 at 11:48 am
Sampat Kumar
Ansys EmployeeHi Jean,
Please follow the link that I have shared here.
https://ansyskm.ansys.com/forums/topic/how-do-i-get-points-in-spaceclaim-to-transfer-to-mechanical/#:~:text=Independent%20points%20created%20in%20SpaceClaim%20are%20not%20imported,beam.%20Beams%20must%20be%20split%20at%20the%20location.
A point doesn't directly transfer from SC to Ansys mechanical.
sampat -
November 6, 2023 at 9:41 am
Jean COLLOMB
SubscriberHi Sampat,
Thanks for your answer.
As a point doesn't directly transfer from SC to Ansys Mechanical, is there another solution for my problem ?
Jean
- pcb
- No longer possible to import f3d with 2023?
- line bodies and surface body shared topology
- How to chang unit in Ansys Discovery 2023?
- ANSYSLI Exited or could not read server port ANSYSLI_FNE_PORT
- SpaceClaim Script: Selection by FilterByBoundingBox
- Assignment of revolute joint
- Max/min over time results in AIM
- Axisymmetric model – Rubber seal
- To change language in Ansys Discovery
8808
4658
3155
1688
1478
