Discovery Import
Discovery Import
Spaceclaim has stopped working
    • nicolas.bouley
          Spaceclaim has stopped working I have a perpetual license with an up-to-date subscription. Windows 7 pro x64, 16Gb of Ram, GeForce GTX 750Ti, Core i5 3.30Ghz impossible to launch "discovery spaceclaim", after the start of program, one window appears for indicate SpaceClaim has stopped working. i have tested the answer here, but not working again. https://discoveryforum.ansys.com/t/80g9av/discovery-live-19-0-doesnt-work-and-the-error-is-spaceclaim See the détails of problem: Signature du problème : Nom d’événement de problème:    CLR20r3 Signature du problème 01:    SpaceClaim.exe Signature du problème 02:    2018.1.36864.37377 Signature du problème 03:    5ad788c3 Signature du problème 04:    System Signature du problème 05:    4.7.3130.0 Signature du problème 06:    5b176097 Signature du problème 07:    209a Signature du problème 08:    158 Signature du problème 09:    System.AggregateException Version du système:    6.1.7601.2.1.0.256.48 Identificateur de paramètres régionaux:    1036 Information supplémentaire n° 1:    d32b Information supplémentaire n° 2:    d32ba35a401f4351e73ab3f0b491ebf5 Information supplémentaire n° 3:    7790 Information supplémentaire n° 4:    7790f3d76bf988aa93afa6662548e10d
    • Subashni Ravichandran
      Hi  nicolas Your graphics card GeForce GTX 750Ti does not support Discovery Live. To see a list of compatible Graphics card please check this link. To check compatibility of your machine you can also go through this link .
      nicolas
      We see from our database that your license has not been activated yet. I suggest you go through this link  and make changes to your firewall and then try again.
    • nicolas.bouley
      I know for "Discovery Live" but my problem is for SpaceClaim.
      with Spaceclaim 2017 no problem but with update for Sc19.1, this version not working, impossible to launch.
    • nicolas.bouley
      Thanks for the link.
      Firewall configured and now spaceClaim works again.
Viewing 4 reply threads
