3D Design
3D Design
SpaceClaim: How do I parametrize an area?
    • julius.langenhorst
      Hello,nI would like to parameterize a simple area, Height x Width with no thickness. Either the two sides should be parameter or the area as a whole.nSo far, I tried creating the area pulling lines out of a single point. This gets me four lines that can be set as parameters. If if use 'fill' to create an area I still keep my parameters but the area doesn't change when I change the parameters. Only the lines themselves change. Could you help me out with this trivial problem?nThank you!n
    • peteroznewman
      nFirst sketch the rectangle and return to 3D so it becomes a surface.nThen use the Pull Tool on the top edge, but click on the Ruler icon to measure the pull from the bottom edge then click on the P and then name that group Height.nRepeat for the right edge. The key is to use the Ruler on the pop-up.nnn
      Thanks! This works perfectlyn
