November 12, 2020 at 10:29 am
Roberto
SubscriberHello
Sometimes these bad behavior of spaceclaim happen to me, I can send files and videos.
I can send files privately
Best Regards
November 12, 2020 at 12:22 pm
Subashni Ravichandran
Forum ModeratorHello Roberto
Can you please explain more elaborately what is the issue you are facing?
I have shared a secure transfer link to you via email. Please use the link to share the files.
November 12, 2020 at 2:07 pm
Roberto
SubscriberHello Subashni
The problem is that when I join two bodies they don't join properly.
It unites them but it is as if it did not unite as the color is different and the faces dividedBest Regards
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
8782
4658
3151
1678
1464
