Discovery Import
Discovery Import
SpaceClaim – info of thread
    • l.janicek
      could you tell me if I can user change the info of thread for all future threads (Standard hole), because the info is too long in Czech languague. The info you can see in the attached picture.
      Thank you, Lukas
    • Naresh Patre
      Hello Lukas
      I am not sure if it's possible to change the thread information. Let me check with the team and get back to you.
    • jsuneby
      Hi  Lukas If you right-click the dimension, you can select "Detach from Dimension." This will allow you to edit the dimension annotation. However, this breaks the connection with the dimension such that, if you change the standard hole size/type, the changes will not occur in the annotation (and you will have to re-add the dimension annotation). I will file an enhancement request for the Czech translation of Tap Drill to be more succinct.
      • l.janicek
        Hi Josh Suneby
        I know I can use the Detach from dimension, but there is the problem you wrote about.
        Thank you, Lukas
