November 9, 2018 at 10:15 am
Rizwan
Subscriberwhen I am selecting the spaceclaim after a geometry input for 2D steady state thermal problem it is not showing any coordinate axes,planes,grids as shown in the video of 'edx' module course of 'a hands on introduction to engg.simulations'.What is wrong? Instead I am getting a grey screen with all the tool bars
November 9, 2018 at 11:18 am
Sandeep Medikonda
Ansys EmployeeTry the steps in these 2 discussions (Discussion 1 & Discussion 2) and if it doesn't work please Post a picture?
November 9, 2018 at 12:04 pm
SubscriberI believe it may be a problem with your graphics card. Please install the latest driver.
In SpaceClaim, you can request different Rendering Engines. Try a different one.
ANSYS has a list of graphics cards that they use to test their software to make sure it works properly on those cards. If you want reliable operation, buy a tested graphics card. Some of them are for laptops.
November 9, 2018 at 12:46 pm
Rizwan
SubscriberThanks a lot Mr Moderator,I selected a different rendering engine Direct3D9 and it worked
November 12, 2018 at 7:20 am
Keyur Kanade
Ansys EmployeeYes, selecting different rendering helps.
Can you please mark this as Is Solution so that others on forum can benefit.
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
