Spaceclaim: Issue with creating user defined infill
    • u1112095
      Hello all,
      I'm a masters student at the University of Southern Queensland in Australia.
      I am having an issue with user defined infill using spacecalim, essentially when I try to use the custom infill option using user defined surface, the individual parts of the infill arent connected.
      Below is a screenshot detailing the issue I'm having. Am I missing something here or is this a limitation of SC?
      Any feedback appreciated
    • bhagwantP
      Hello u1112095,
      Can you try to use gap option in repair tab to detect these gaps and fix them? For detecting these gaps you can set tolerance value bit more than 0.01mm.
      Hope this helps to close these gaps.
