February 7, 2022 at 1:41 am
jl2323
SubscriberWhenever I perform a specific projection to a surface, when I save, the next time I open the file I get an error that says "object reference not set to an instance of an object"
February 7, 2022 at 4:42 am
Subashni Ravichandran
Ansys EmployeeHello Jamie Levinson
Does this issue happen with any one specific file ? Can you please share that file if possible?
Can you please use the "Check geometry" feature to see if there are any geometry issues with the projection? If there are, please try to rectify them and try again. -
February 12, 2022 at 5:51 pm
jl2323
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
So, it only happens when I do one specific projection. Other projections seems to work fine. So, I did use the "Check Geometry" feature. I get some split edges and repair those however, I have done that every time and the problem still occurs. Here are the files before and after the projection. I project "Group 1" through the entire outer part. I project through the entire solid. When I open the file after saving it after the projection, no matter what happens, any action results in an error.
P.S. Sorry it took so long to respond. Work kept me busy.
February 12, 2022 at 8:20 pm
jl2323
SubscriberSo, I figured out a way to fix it was to detach the surfaces that I thought were causing the problem, and then recombining them. For holes that were causing them, I detached the surfaces and then used those surfaces to extrude(cut) the holes again.
3812
2605
1849
1244
600
