3D Design
3D Design
Topics related to Ansys Discovery and Ansys SpaceClaim.
SpaceClaim Script: Selection by FilterByBoundingBox
    • ramiromena
      Dear Ansys Learning Forum Community,
      I am trying to select a specific face in a geometry. The easiest way to do this task is by knowing in advance the index of the face of interest. However, this option lacks of scalability if my geometry is modified or generated in a different order. This solution is referred as Option 1.
      So, other option is to use the FilterByArea method. This works fine as long as your faces have a unique area, otherwise, you will select multiple faces instead of only one. This solution is referred as Option 2.
      Then, by searching the available options, there is the FilterByBoundingBox method where you can select a face that intersects with a previously defined box. This method looks as the most generic so that you can control the way a face is selected. However, due to the lack of documentation in SpaceClaim or the absence of a similar example, I am not able to use this method properly. Maybe is due to an error in the syntax or in my understanding of the method. Please, could you help me? This solution is referred as Option 3.
      Attached you will find a minimal working example (MWE) with the implementation of Option 1, 2 and 3. This last one is currently not working as is the one I am interested the most. Feel free to add/modify its content.
      However, if you know a better solution to select a specific face (i.e based on its normal or another feature, feel free to share your valuable know-how)
      As always, thank you for your help.
      Best regards,
      Ramiro
      Minimal Working Example MWE
      Author: Ramiro MENA ANDRADE
      Date: 2023-06-12
      Script to generate a Cube of dimensions Cube_X, Cube_Y and Cube_Z
      and select faces based on three different methods:
          - Option1: When the index of the face is known in advance (not useful to fully automatize a code)
          - Option2: By using FilterByArea method (not useful if more than one face has the same area)
          - Option3: By using FilterByBoundingBox method (could be useful, but I do not know how to write the proper syntax)
      # Python Script, API Version = V19
      # Part 1: Geometry definition (dimensions in mm)
      Cube_X= 10
      Cube_Y= 20
      Cube_Z= 5
      pointA = [0,0]
      pointB = [Cube_X,0]
      pointC = [Cube_X,Cube_Y]
      tol = 0.01 #define a tolerance
      area = Cube_X*Cube_Y #calculate the area
      #Part2: Geometry generation
      sectionPlane = Plane.PlaneXY
      result = ViewHelper.SetSketchPlane(sectionPlane, None)
      # EndBlock
      # Set New Sketch
      result = SketchHelper.StartConstraintSketching()
      # EndBlock
      # Sketch Rectangle
      point1 = Point2D.Create(MM(pointA[0]),MM(pointA[1]))
      point2 = Point2D.Create(MM(pointB[0]),MM(pointB[1]))
      point3 = Point2D.Create(MM(pointC[0]),MM(pointC[1]))
      result = SketchRectangle.Create(point1, point2, point3)
      # Solidify Sketch
      mode = InteractionMode.Solid
      result = ViewHelper.SetViewMode(mode, None)
      # EndBlock
      # Extrude 1 Face
      selection = FaceSelection.Create(GetRootPart().Bodies[0].Faces[:])
      options = ExtrudeFaceOptions()
      options.ExtrudeType = ExtrudeType.Add
      result = ExtrudeFaces.Execute(selection, MM(Cube_Z), options)
      # EndBlock
      #Part 3: Selection of faces by different methods
      # OPTION 1: Create Named Selection Group (Top)
      # PROBLEM: YOU NEED TO KNOW IN ADVANCE THE INDEX OF THE FACE
      primarySelection = FaceSelection.Create(GetRootPart().Bodies[0].Faces[0])
      secondarySelection = Selection.Empty()
      result = NamedSelection.Create(primarySelection, secondarySelection)
      result = NamedSelection.Rename("Group1", "Option1")
      # EndBlock
      #OPTION 2: Create a named selection by using FilterByArea
      #PROBLEM: FOR THIS CASE, MULTIPLE FACES CAN HAVE THE SAME AREA, SO YOU CAN NOT SELECT A SPECIFIC FACE
      comp = Selection.Create(GetRootPart())
      faces = comp.ConvertToFaces().FilterByArea(MM2(area-tol),MM2(area+tol))
      faces.CreateAGroup('Option2')
      #OPTION 3: Create a named selection by using FilterByBoundingBox Method
      #PROBLEM: I DO NOT KNOW THE PROPER SYNTAX FOR USING THIS METHOD CORRECTLY
      #Create Points
      min_point = Point.Create(MM(pointA[0]), MM(pointA[1]), MM(0))
      max_point = Point.Create(MM(pointC[0]), MM(pointC[1]), MM(0))
      #Create a Box
      mbox = Box.Create(min_point, max_point)
      #Apply the Filter to a face (fface means filtered face)
      fface = comp.ConvertToFaces().FilterByBoundingBox(mbox)
      fface.CreateAGroup('Option3')
    • Aniket
      Hi Ramiro,
      First of all very well-written question! Kudos for that! There was an issue in older APIs of FilterByBoundingBox which is fixed in 2023 R1.
      so something, as follows, would work in 2023R1:
      from SpaceClaim.Api.V23 import *
      PartSel = Selection.Create(GetRootPart())
      faces = PartSel.ConvertToFaces()
      BoundingBox = Box.Create(MM(-30),MM(-30),MM(-30),MM(30),MM(30),MM(30))
      facesInBoundingBox = faces.FilterByBoundingBox(BoundingBox)
      You may want to upgrade to 2023R1.
      If that's not possible, possibly you can loop through faces and check their centroid such as:
      GetRootPart().Bodies[0].Faces[0].EvalMid().Point
      -Aniket
    • ramiromena
      Hi Aniket.
      Thank you for your positive feedback and for your quick reply. Currently I do not have the 2023R1 version, but I am glad to know that there is a solution in the future version. In the meantime, the hint of using the centroid is super useful.
      I will proceed to update my script and kudos for you too :).
      Cheers,
      Ramiro
