March 28, 2022 at 8:17 am
UoS_CAE
SubscriberI am trying to import in a solidworks file via scripting feature in Spaceclaim with associated parameters which workbench can use in mechanical for optimisation studies. I can successfully import in the Solidworks geometry via script feature, but I can’t seem to import and select the parameters of interest similar to the capability available with block recording, where the parameters can be selected via a drop down. Can anyone help? Thank you.
Here is the script i am using currently:
# Insert From File
importOptions = WorkbenchSettings()
importOptions.SolidBodies = True
importOptions.Parameters = ParameterImport.Independent # similar to block recording
importOptions.ParameterKey = r"ANS;DS" # similar to block recording
DocumentInsert.Execute(r"D:SimulationsExample problemSubmodel - solid and shell.SLDPRT", importOptions, GetMaps("0107d617")) # the get maps id is taken from the python recording feature
# EndBlock
March 30, 2022 at 12:54 pmAshish Khemka
Please see if the following link helps:
How to Use SpaceClaim Scripting to Parameterize Your Models - Bing video
Regards Ashish Khemka
Trending discussions- ANSYS Workbench Measuring within Design
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2600
2088
1319
1108
459
