Ansys Free Student Software
SpaceClaim – The geometry editor was closed abnormally.
    • mach1991
      Greetings to all. I have version 19.2 of ansys student installed. I am presenting the problem "The geometry editor was closed abnormally". How can I solve this, because this does not allow to continue with the normal workflow when using SpaceClaim. Thank you first.
    • tsiriaks
      Please try the instructions here
      https://studentcommunity.ansys.com/thread/problem-with-ansys-18-2-space-claim/
      Thank you,
      Win
    • mach1991
      Hi good day. I come from that thread, make the raisins that you indicate, my problem persists.
    • tsiriaks
      Hi mach1991,
      Can you launch stand-alone SpaceClaim ?
      Win
    • mach1991
      Yes, the program opens without problems.
    • tsiriaks
      Please post the screenshot of the value of
      HKEY_CLASSES_ROOTSpaceClaim.AnsysSCDM.192
    • mach1991
       it is ok? PD:
      By the way. My pc is in spanish because i'm from venezuela. At the default value says (value without assigning)
    • tsiriaks
      On the 'Data' column for the 'Path' , is it
      C:Program FilesANSYS IncANSYS Studentv192scdm
      or
      C:Program FilesANSYS IncANSYS Studentv192SCDM
      Also, check with the Windows File Explorer and make sure that that path exists.
    • mach1991
      Good evening, if the route is correct and the address in the browser also exists. I do not know what happens
    • tsiriaks
      Can you extend that 'Data' column to show the full path ?
    • mach1991
      of course..
    • tsiriaks
      Open CMD Prompt, then issue this command (with quote " " )
      "C:Program FilesANSYS IncANSYS Studentv192scdmSpaceClaim.exe"
      Does this launch stand-alone SpaceClaim ?
      If so, issue the command
      set a
      and post the output here
    • mach1991
      Good day, yes, the command launches the program without problems ..
    • tsiriaks
      please provide this output
      set a
    • mach1991
      Goodnight. What do you mean by "this output set a"
    • tsiriaks
      it's in my previous instructions
      set a
    • mach1991
      Good morning. Here it is!
    • tsiriaks
      ok, so after this, in the CMD Prompt, could you type
      set a
      then press 'enter' and show the output of it ?
    • mach1991
    • tsiriaks
      Open elevated (Administrator) CMD Prompt (right click on CMD and 'run as administrator'), then issue the following command
      "C:Program FilesANSYS IncANSYS Studentv192FrameworkbinWin64runwb2.exe"
      Can you launch SpaceClaim from this Workbench session?
    • mach1991
      The same message "the geometry editor was closed abnormally". I can´t understad this problem. T-T. There is not solution??
    • mach1991
      Here is how is config. in workbench. Like a default.
    • tsiriaks
      Sorry , I'm running out of idea. I will ask other folks to look and see if they have other thoughts
      In the meantime, since one of the most common causes of issue we've seen in this forum is localization, can you try
      - Create a test Windows user account with the name that doesn't have underscore ' _ ' , like abc, or a123.
      - Make sure your system is using English language as default , ref : https://us.answers.acer.com/app/answers/detail/a_id/45924/~/change-the-operating-system-language-on-acer-windows-10-computers
    • mach1991
      As I understand. RaguShiva was able to solve the problem, but he does not connect to the forum since then, I will try to change the default language..
    • mach1991
      I try to change the pc language and error persists. It is as if the plugin that integrates into the SpaceClaim workbench will not be configured. If you have some ideas from other colleagues, what I have seen is an error that happens frequently.
    • tsiriaks
      I'm still asking around for any thoughts on this issue.
      Just to verify, have you also tried creating a dummy username with simple english letters or numbers ?
    • tsiriaks
      Also, just for a kick, Go to HKEY_CLASSES_ROOTSpaceClaim.AnsysSCDM.192 again and remove/delete the 'Path' , close the registry editor, then open up an elevated CMD Prompt and issue the following command (this is one line)
      reg add HKEY_CLASSES_ROOTSpaceClaim.AnsysSCDM.192 /v Path /t Reg_Sz /d "C:Program FilesANSYS IncANSYS Studentv192scdm" /f
      Does this make any difference ?
    • mach1991
      I tried, but it did not work ..
    • tsiriaks
      What was the username of the dummy account that you tried ?
    • mach1991
      Try it in the main account, change the language and then your last suggestion.
    • tsiriaks
      Can you just try creating a test account ? Just name it abc.
    • mach1991
      Hello tsiriaks Goodnight. Try what you suggested but it did not work.
    • tsiriaks
      What about this
      open normal (non-elevated) CMD Prompt, then issue the following commands
      move %LOCALAPPDATA%SpaceClaim %LOCALAPPDATA%SpaceClaim.back
      move %APPDATA%SpaceClaim %APPDATA%SpaceClaim.back
      move %APPDATA%Ansys %APPDATA%Ansys.back
      set PATH=C:WINDOWSsystem32;C:WINDOWS;C:WINDOWSSystem32Wbem
    • mach1991
      I tried, but it did not work. The first time I opened SpaceClaim this time, he did not give the message. The second time I tried to open it, I throw the error.
    • tsiriaks
      You meant after you did that, the first time it worked fine but when you tried the second time, it threw the error message again ?
      So, you meant each time you follow the steps, it would work once ?
      This info is very critical, please let me know the symptom in details.
      Thanks,
      Win
    • mach1991
       Hello tsiriaks, do you have any new information or suggestions? The problem still persists.
    • tsiriaks
      Please answer the question above.
    • mach1991
      What I meant. Once the steps are followed, the first one that opens Space Claim, does not launch the error message, but still does not link it as a direct modeler. It just does not give the error message. If I close the program and reopen it, it gives the error message.
    • tsiriaks
      Can you try updating your graphics driver ?
      Once that is done, open CMD Prompt, then type
      dxdiag
      then, 'enter'. Post the screenshot of 'Display' tab here.
      Also, try this. Open stand-alone SC , then File -> SpaceClaim Options -> Advanced -> Renderer -> WARP
      Then, try opening SC from Workbench again.
    • tsiriaks
      Also, try the followings
      go to
      C:Program FilesANSYS IncANSYS Studentv192commonfilesconfigswinx64unconfig
      then right click on AnsUnconfigSpaceClaim.exe and 'run as administrator'
      now, go to
      C:Program FilesANSYS IncANSYS Studentv192commonfilesconfigswinx64config
      then right click on AnsConfigSpaceClaim.exe and 'run as administrator'
    • mach1991
      I have a funny history for you, the problem disappeared with the instalation of R1 2019.. I don't understand, but is gone.. hahaha. thanks for everything
    • tsiriaks
      Just to make sure, you meant you didn't do anything but just installed 2019 R1 , then the issue with v19.2 disappeared ?
    • mach1991
      Not really, I mean when the version changes, the bug is not. I guess it was a compatibility issue that was corrected in R1. It's funny because the problem had been happening to me since 18.2
    • tsiriaks
      This actually means your installation for 2019 R1 is done successfully without any glitch/error. There are some issues with your installation for previous versions, unfortunately, we couldn't figure out where exactly.
    • moeenkhurram
      HI @tsiriaks  is there nay proper solution for this ? I tired every thing , still facing the same problem
    • tsiriaks
      can you launch stand-alone SpaceClaim ?
      It's the issue with your systems can't properly write/modify some Windows registries, which are used by SpaceClaim
Viewing 45 reply threads
