January 2, 2023 at 10:33 am
sivelina
SubscriberHello!
1.I have a geometry model drawn on SpaceClaim. I want to import it into DesignModeler. In what format should the geometry model file be saved?
2. I have a geometry model drawn on SpaceClaim and saved in format ".scdog".What is the next step to convert to Mesh? -
January 3, 2023 at 5:06 am
Keyur Kanade
Ansys EmployeeFrom SpaceClaim you can export neutral format like step iges or parasolid and then import it in DM. If you have student license, please check the formats allowed.
From SpaceClaim you need to go to Ansys Meshing or Fluent Meshing to generate a mesh for geometry.
Please check following videos
Ansys Meshing Sizing:
Fluent Meshing Watertight Workflow:
Ansys Meshing: Meshing Methods:
Please go through help manual for more details
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2534
2066
1285
1104
459
