Preprocessing
Preprocessing
Spaceclaim to Mechanical Geometry Handling Problem
    • Adam Miller
      In the past, I've been able to share topology and combine perfectly adacent components in Spaceclaim as a new component and had them show up as a combined part in Mechanical, which would result in components that would allow me to refine a mesh in an efficient way, but also, would still behave as a single component. Now, however, doing exactly what I used to do, it seems there's some kind of handoff problem between Spaceclaim and Mechanical, and components that were combined in Spaceclaim as a single part are now acting like separate parts in Mechanical. Anyone have this issue as well?
    • Adam Miller
      FYI, apparently there was nothing wrong with my process, somehow the geometry was just getting corrupted in Workbench so I tore it down, started over, same process in Spaceclaim, and now it's working. HOWEVER... if you've done what I'm describing in the past and are confused, as I was, by how thing show up in the Mechanical model tree, just know that Mechanical will treat combined bodies with shared topology from Spaceclaim appropriately, but, it will NOT show up like it used to in previous ANSYS releases as a "combined" part in the Mechanical model tree; they now look like separate parts there for some reason. I much prefered the previous release's handling of Spaceclaim geometry so that it was obvious in Mechanical, what was going to behave as a combined component.
