September 18, 2023 at 12:08 pm
September 20, 2023 at 11:26 am
Atharv Joshi
Forum ModeratorHi Scott,
Can you please check if you have installed the pre-requisites mentioned in the error message? Refer to this knowledge article for miscellaneous requirements Ansys Discovery Hardware Requirements (2023 R2) - Ansys Knowledge
Thanks and Regards
Atharv
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7592
4440
2953
1427
1322
