March 20, 2022 at 12:57 pm
seghier
SubscriberHi
I use an external python editor to send some commands to Spaceclaim but for some commands like:
Group.SetDimensionValue
i got this error message:
Runtime error (InvalidOperationException): Write calls are only allowed inside a write block.
How i can solve this problem with write block?
March 21, 2022 at 3:31 pmAniket
Ansys EmployeeThis should be doable using something on the following lines:
from SpaceClaim.Api.V19 import Taskas NewTask
from SpaceClaim.Api.V19 importWriteBlock
def myfunction():
# your code here
myTask=NewTask(myfunction)
WriteBlock.ExecuteTask('Running myFunction', myTask)
-Aniket
March 21, 2022 at 4:05 pmseghier
SubscriberThank you
Works fine , thank you very much Aniket
March 26, 2022 at 2:38 pmMarch 26, 2022 at 7:18 pmViewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7656
4468
2957
1429
1322
