Discovery Import
Discovery Import
SpaceClaim’s required memory capacity to handling large assemble data
    • miyado
      I received a question from our customers that SpaceClaim hard to read/handle massive CATIA assembly data (catproduct) .
      Is there any rough standard of how much RAM is required to handle large assembly data (eg 1 GB)?
    • Subashni Ravichandran
      Hi  Miyado
      I would suggest clearing out temporary files by going to %Temp% on Windows. Furthur, at SpaceClaim options> Advanced, reducing undo steps and restarting should help save up some RAM. Also, please ensure other memory consuming applications are closed for better performance of SpaceClaim.
      • miyado
        Subashni
        Thank you for your advice.
        And now, how much memory is necessary to handle large assembly data consisting of hundreds of parts ?
      Miyado
      For a 1GB file, a 32 or 64 GB RAM should do good.
      Another way to keep the RAM use low is to use the Lightweight state for components you don't need immediately.  A lightweight assembly component uses less memory than an object that is fully loaded.  When you are ready to work with it, you can load the geometry information.
      Right-click the component in the Structure tree and select Make Lightweight from the context menu.
      The component becomes lightweight and uses less memory. You cannot make an internal component lightweight.
      • miyado
        Subashni
        Thank you !
        It was useful information.
