September 23, 2018 at 5:33 am
September 23, 2018 at 12:07 pm
SubscriberSorry if you already tried this, but did you click the Home button that fits the contents to the display? Maybe you are just zoomed in so close you can't see the model.
If you put the *.sat file into a *.zip file, you can attach it and I will try it. Also say the version of ANSYS you are using.
September 24, 2018 at 9:21 am
Ansys EmployeeCan you also try and draw something in SpaceClaim without importing - that way we know the graphics etc are working. The fact that all the tool menus are greyed out suggests something is wrong. The other possibility is that you have too many objects in the import, I think you're limited to about 300 bodies.
September 25, 2018 at 4:56 am
Keyur Kanade
Ansys EmployeeTry File --> SpaceCliam options --> Advanced --> Graphics
Change rendering option and restart spaceclaim.
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1279
1096
457
