Sparse Solver in UDF
    • magissimus
      Hello.
      I created a post on old version of forum regarding the topic of linking intel MKL to UDF. I got a response that it is not possible, thanks for Kremella for answer. Kremella also mentioned that maybe it will be possible to find alternate option of solving my problem if I describe my goal.
      I am simulating a heat transfer in multilayer, porous material with focus on radiation. For some reasons I am not using the Fluent radiation models (I can explain why, but it is not important), but I use my own radiation model written in C. It was tested and works properly. Now I want to solve the energy equation (and flow in the future) using Fluent and use my own model to calculate the radiation heat transfer using a couple of UDFs. In one UDF I need to solve a sparse matrix and previously I was using intel MKL PARDISO for this and that is why I wanted to link mkl to Fluent. However I can use any efficient sparse matrix solver.
      So my general questions is: is there a possibility to use an external library which have sparse solver (e.g. LAPACK)? If yes how to achieve that or where should I look for a help?
      I would be grateful for any help.
      Test
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/aas_usr/aas_usr.html
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v221/en/flu_udf/flu_udf_sec_precompiled_objects.html
      Have a look in the links - yes it can be done, but it's not going to be easy.
    • DrAmine
      Good Luck.
Viewing 5 reply threads
