August 6, 2018 at 3:13 pm
waqar932432
SubscriberI HAVE IMPORTED A GAS PHASE AND A SURFACE REACTION CHEMKIN MECHANISM in ANSYS FLUENT. There are two zones in this case. one solid and other is for passage of gas. i have set surface mechanism set on wall of solid and gas phase mechanism in gas zone. I have set chemkin mixture as material in gas zone, how should i set solid zone. do i need to define it as a species from chemkin mixture material or i can pick other than from chemkin mixture material?
Regards
Waqar
August 7, 2018 at 5:43 am
DrAmine
Ansys EmployeeThe solid zone could be assigned to a solid material.
August 7, 2018 at 6:25 am
waqar932432
Subscriberi have defined that zone as fluid zone and assigned carbon-solid (which is found in fluent fluids library) to it. is it alright?
August 7, 2018 at 7:34 am
DrAmine
Ansys EmployeeWhy as fluid zone? Just define it as solid zone (by changing the type) so that only energy equation is solved.
2518
2064
1279
1094
456
