Species source in complex geometry
    • Meyzeeh
      Hi Everyone
      Can I ask how you would add a species source in the near wall cells if the shape of the geometry were not simple enough to use hex, cylinder, or sphere to create a cell register? I'm trying to model a problem where the walls of a complex tunnel geometry are a species source and there is air ventilation.
      Have a look at boundary registers. Otherwise you may need to create fluid regions at the geometry stage.
    • Meyzeeh
      Thank you very much. I will try both methods.
  • The topic ‘Species source in complex geometry’ is closed to new replies.
