September 20, 2018 at 11:07 am
maliuzair
SubscriberHi all
Can I model a species mixture as a granular phase in eulerian multiphase model?
When i used 2 granular phases (biomass, sand) without species transport, there is no problem with convergence
But when i switch to species transport with 2 granular phases (one is a mixture of 2 species and the other is sand), then the simulations dont converge. then i turned off the granular option for mixture and everything worked perfectly. Please explain this problem
Besides, I have another problem.
"THE TEMPERATURE IS LIMITED TO 270 IN 1901 CELLS ON ZONE 2 IN DOMAIN 3..." How can i address this issue except using the limits option in controls bar..
Thank you.
September 23, 2018 at 4:57 pm
DrAmine
Ansys EmployeeYes you can model that. The warning might be due to the fact that there is a rapid and large temperature drop due to phase change, reactions, wrong boundaries., etc.
Additional details about your case are relevant to help you.
2726
2146
1357
1150
462
