December 9, 2019 at 6:35 am
rjoshi
SubscriberHow is temperature calculated in DEFINE_SPECIFIC_HEAT for a material in UDF.
DEFINE_SPECIFIC_HEAT(xxx,T,Tref,h,yi)
real cp2 = 2000;
*h=cp2*(T-Tref); // How is T called here as we don't define cell and thread inside the macro //
return cp2;
Also since *h is calculated why do i return cp ?
Rahul
December 9, 2019 at 4:34 pm
DrAmine
Ansys EmployeeThe second why is what Fluent internally wants to know. The first part of the question the actual cell temperature is passed from Fluent to the macro and ready to use. -
December 10, 2019 at 7:44 am
rjoshi
SubscriberHi abenhadj,
So if Cp function of temperature I can just directly write the equation under DEFINE_SPECIFIC_HEAT and use it for calculation of Cp without assigning a constant value to it ?
Rahul
December 10, 2019 at 3:19 pm
Ansys EmployeeWhy not use a piecewise linear or polynomial over the UDF?
December 10, 2019 at 4:57 pm
DrAmine
Ansys EmployeeStick to what rwoolhou suggested. If the function is very complex then udf. -
December 11, 2019 at 3:35 am
rjoshi
SubscriberHI rwoolhou,
Will try to implement your suggestion.
Rahul
5290
3311
2471
