February 8, 2018 at 4:59 pm
sageblade
SubscriberIs there any way to specify the direction of magnetization (or north and south poles) on a geometry? I am trying to simulate the magnetic fields of multiple bar magnets in different arrangements
February 8, 2018 at 6:50 pm
Vishal Ganore
Ansys EmployeePlease see this tutorial: https://confluence.cornell.
edu/display/SIMULATION/ANSYS+ AIM+-+Permanent+Magnetic+ Circuit+with+Air+Gap -
February 8, 2018 at 7:16 pm
sageblade
SubscriberI'm a little confused as to what values I am supposed to put in for x, y, and z? For instance, if my bar magnet is magnetized through thickness, oriented with the south pole on the bottom and the north pole on the top, would my y value be 1 and x & z would be 0?
Thanks for your help!
- Maxwell, HFSS or Q3D?
- Error
2726
2156
1359
1150
462
