July 29, 2019 at 4:52 am
asyraffx
SubscriberI'm trying to specify the permeability of the porous medium, approx. 1.43e-21 m^2. But under the "Permeability and Loss Coefficient" option, it only allows to go as low as e-20 m^2. Is there anyway I could bypass this limit?
July 29, 2019 at 1:57 pm
Ansys EmployeeIf your permeability is that low do you expect any flow? The limits in Fluent are (usually) there to stop you adding in source terms that'll mess up the numerics: you can't bypass them.
July 29, 2019 at 4:26 pm
asyraffx
SubscriberAccording to the reference, there should be some flow through the porous domain using the specify the permeability. I just found out I could override the source terms limit using UDF.
Thanks
2534
2066
1285
1104
459
