June 9, 2023 at 8:06 pm
Daniel Eichorn
SubscriberI am running Random Vibration on "Enterprise" version and get this:
*** ERROR *** CP = 0.203 TIME= 14:54:00
The option of SPECTR on the ANTYPE command is either not available for
this version of Ansys or the appropriate product was not selected for
this session.
Contact your Ansys support person for more information.What does this mean? No license?
June 12, 2023 at 12:00 pm
Aniket
Ansys Employee -
June 12, 2023 at 1:15 pm
Daniel Eichorn
SubscriberI reran the analysis this morning and there were no issues. I cannot explain why, nothing changed except the time at which I ran it.
I then added "Fatigue Tool" - both "Life" and "Damage". Updating produces this new error: "To proceed with Fatigue analysis, 'Calculate Velocity' and 'Calculate Acceleration' in Output Controls must be set to Yes."
I set these to "Yes" in Options>Analysis Settings and Solution but the error persists.
June 12, 2023 at 1:20 pm
Daniel Eichorn
SubscriberDiscovered that Calculate Acceleration/Calculate Velocity are under Random Vibration Analysis Settings and don't seem related to the same function in Options... Analysis ran.
June 12, 2023 at 2:46 pm
Daniel Eichorn
SubscriberInitial issue happened again...
@Aniket - per your request:
2023 R1
Point Releases and Patches installed:
ANSYS, Inc. License Manager 2023 R1
Discovery 2023 R1
SpaceClaim 2023 R1
Ansys Sherlock 2023 R1
Autodyn 2023 R1
LS-DYNA 2023 R1
CFD-Post only 2023 R1
CFX (includes CFD-Post) 2023 R1
Chemkin 2023 R1
EnSight 2023 R1
FENSAP-ICE 2023 R1
Fluent (includes CFD-Post) 2023 R1
Polyflow (includes CFD-Post) 2023 R1
Forte (includes EnSight) 2023 R1
TurboGrid 2023 R1
ICEM CFD 2023 R1
Motion 2023 R1
Aqwa 2023 R1
Speos 2023 R1
Speos HPC 2023 R1
Speos for NX 2023 R1
optiSLang 2023 R1
Additive 2023 R1
Customization Files for User Programmable Features 2023 R1
Mechanical Products 2023 R1
Material Calibration App 2023 R1
Icepak (includes CFD-Post) 2023 R1
Remote Solve Manager Standalone Services 2023 R1
Ansys Sound - SAS 2023 R1
Viewer 2023 R1
ACIS Geometry Interface 2023 R1
AutoCAD Geometry Interface 2023 R1
Catia, Version 4 Geometry Interface 2023 R1
Catia, Version 5 Geometry Interface 2023 R1
Catia, Version 6 Geometry Interface 2023 R1
Creo Elements/Direct Modeling Geometry Interface 2023 R1
Creo Parametric Geometry Interface 2023 R1
Inventor Geometry Interface 2023 R1
JTOpen Geometry Interface 2023 R1
NX Geometry Interface 2023 R1
Parasolid Geometry Interface 2023 R1
Solid Edge Geometry Interface 2023 R1
SOLIDWORKS Geometry Interface 2023 R1
***** MAPDL COMMAND LINE ARGUMENTS *****
BATCH MODE REQUESTED (-b) = NOLIST
INPUT FILE COPY MODE (-c) = COPY
DISTRIBUTED MEMORY PARALLEL REQUESTED
4 PARALLEL PROCESSES REQUESTED WITH SINGLE THREAD PER PROCESS
TOTAL OF 4 CORES REQUESTED
INPUT FILE NAME = C:\Users\user\Downloads\_ProjectScratch\Scr531A\dummy.dat
OUTPUT FILE NAME = C:\Users\user\Downloads\_ProjectScratch\Scr531A\solve.out
START-UP FILE MODE = NOREAD
STOP FILE MODE = NOREAD
RELEASE= 2023 R1 BUILD= 23.1 UP20221128 VERSION=WINDOWS x64
CURRENT JOBNAME=file0 10:30:51 JUN 12, 2023 CP= 0.141
PARAMETER _DS_PROGRESS = 999.0000000
/INPUT FILE= ds.dat LINE= 0
*** NOTE *** CP = 0.266 TIME= 10:30:51
The /CONFIG,NOELDB command is not valid in a distributed memory
parallel solution. Command is ignored.
*GET _WALLSTRT FROM ACTI ITEM=TIME WALL VALUE= 10.5141667
*********** Resuming The ANSYS db File from Modal Solution ***********
RESUME ANSYS DATA FROM FILE NAME=C:\Users\user\Downloads\Busbar_files\dp0\SYS-1\MECH\file.db
*** MAPDL GLOBAL STATUS ***
TITLE = Busbar--Modal (A5)
ANALYSIS TYPE = MODAL
1 ELEM TYPES DEFINED MAX ELEM TYPE NUMBER = 1
74795 ELEMENTS DEFINED MAX ELEMENT NUMBER = 74795
127605 NODES DEFINED MAX NODE NUMBER = 127605
1 MATERIALS DEFINED MAX MATERIAL NUMBER = 1
0 REAL CONSTS DEFINED MAX REAL CONST NUMBER = 0
0 SECTIONS DEFINED MAX SECTION NUMBER = 0
0 COORD SYS DEFINED MAX COORD SYS NUMBER = 0
ACTIVE COORDINATE SYSTEM = 0 (CARTESIAN)
NUMBER OF DEFINED NODAL CONSTRAINTS = 2106
NUMBER OF DEFINED NODAL LOADS = 0
NUMBER OF DEFINED COMPONENTS = 3
NUMBER OF DEFINED ELEM SURFACE LOADS = 0
NUMBER OF DEFINED ELEM BODY LOADS = 0
NUMBER OF DEFINED NODE BODY FORCES = 0
CURRENT LOAD CASE = 0 OF 0
LOAD SET = 1
SUBSTEP = 6
TIME/FREQ = 0.0000
INITIAL JOBNAME = file
CURRENT JOBNAME = file
TITLE=
Busbar--Random Vibration (B5)
ACT Extensions:
LSDYNA, 2023.1
5f463412-bd3e-484b-87e7-cbc0a665e474, wbex
/COM, ANSYSMotion, 2023.1
20180725-3f81-49eb-9f31-41364844c769, wbex
***** MAPDL SOLUTION ROUTINE *****
SET PARAMETER DIMENSIONS ON _WB_PROJECTSCRATCH_DIR_PSD
TYPE=STRI DIMENSIONS= 248 1 1
PARAMETER _WB_PROJECTSCRATCH_DIR_PSD(1) = C:\Users\user\Downloads\_ProjectScratch\Scr531A\
SET PARAMETER DIMENSIONS ON _WB_SOLVERFILES_DIR_PSD
PARAMETER _WB_SOLVERFILES_DIR_PSD(1) = C:\Users\user\Downloads\Busbar_files\dp0\SYS\MECH\
SET PARAMETER DIMENSIONS ON _WB_USERFILES_DIR_PSD
PARAMETER _WB_USERFILES_DIR_PSD(1) = C:\Users\user\Downloads\Busbar_files\user_files\
Graphical-Solution-Tracking set to ON
For /MENU,ON or /MENU,GRPH operations, GST ToFile option is ON
FINISH SOLUTION PROCESSING
***** ROUTINE COMPLETED ***** CP = 0.422
*GET _NUMNODE FROM NODE ITEM=COUN VALUE= 127605.000
*GET _NUMELEM FROM ELEM ITEM=COUN VALUE= 74795.0000
*GET _MAXELEMNUM FROM ELEM ITEM=NUM MAX VALUE= 74795.0000
*GET _MAXNODENUM FROM NODE ITEM=NUM MAX VALUE= 127605.000
*GET _MAXELEMTYPE FROM ETYP ITEM=NUM MAX VALUE= 1.00000000
*GET _MAXREALCONST FROM RCON ITEM=NUM MAX VALUE= 0.788860905E-30
--- Number of total nodes = 127605
--- Number of contact elements = 0
--- Number of spring elements = 0
--- Number of bearing elements = 0
--- Number of solid elements = 74795
--- Number of condensed parts = 0
--- Number of total elements = 74795
*GET _WALLBSOL FROM ACTI ITEM=TIME WALL VALUE= 10.5141667
*** ERROR *** CP = 0.438 TIME= 10:30:51
this session.
NUMBER OF WARNING MESSAGES ENCOUNTERED= 0
NUMBER OF ERROR MESSAGES ENCOUNTERED= 1
+--------------------- M A P D L S T A T I S T I C S ------------------------+
Release: 2023 R1 Build: 23.1 Update: UP20221128 Platform: WINDOWS x64
Date Run: 06/12/2023 Time: 10:30 Process ID: 41924
Operating System: Windows 10 (Build: 19043)
Processor Model: Intel(R) Core(TM) i7-10750H CPU @ 2.60GHz
Compiler: Intel(R) Fortran Compiler Version 19.0.5 (Build: 20190815)
Intel(R) C/C++ Compiler Version 19.0.5 (Build: 20190815)
Intel(R) Math Kernel Library Version 2020.0.0 Product Build 20191125
BLAS Library supplied by Intel(R) MKL
Number of machines requested : 1
Total number of cores available : 12
Number of physical cores available : 6
Number of processes requested : 4
Number of threads per process requested : 1
Total number of cores requested : 4 (Distributed Memory Parallel)
MPI Type: INTELMPI
MPI Version: Intel(R) MPI Library 2021.5 for Windows* OS
GPU Acceleration: Not Requested
Job Name: file0
Input File: dummy.dat
Core Machine Name Working Directory
0 MCHNNAME C:\Users\user\Downloads\_ProjectScratch\Scr531A
1 MCHNNAME C:\Users\user\Downloads\_ProjectScratch\Scr531A
2 MCHNNAME C:\Users\user\Downloads\_ProjectScratch\Scr531A
3 MCHNNAME C:\Users\user\Downloads\_ProjectScratch\Scr531A
Latency time from master to core 1 = 4.497 microseconds
Latency time from master to core 2 = 3.795 microseconds
Latency time from master to core 3 = 5.220 microseconds
Communication speed from master to core 1 = 5860.12 MB/sec
Communication speed from master to core 2 = 6472.49 MB/sec
Communication speed from master to core 3 = 6478.15 MB/sec
Total CPU time for main thread : 0.8 seconds
Total CPU time summed for all threads : 0.5 seconds
Elapsed time spent obtaining a license : 0.5 seconds
Elapsed time spent pre-processing model (/PREP7) : 0.0 seconds
Elapsed time spent solution - preprocessing : 0.0 seconds
Elapsed time spent computing solution : 0.0 seconds
Elapsed time spent solution - postprocessing : 0.0 seconds
Elapsed time spent post-processing model (/POST1) : 0.0 seconds
Sum of memory used on all processes : 97.0 MB
Sum of memory allocated on all processes : 5184.0 MB
Physical memory available : 64 GB
Total amount of I/O written to disk : 0.0 GB
Total amount of I/O read from disk : 0.0 GB
+------------------ E N D M A P D L S T A T I S T I C S -------------------+
| RUN COMPLETED |
| Ansys MAPDL 2023 R1 Build 23.1 UP20221128 WINDOWS x64 |
| Database Requested(-db) 1024 MB Scratch Memory Requested 1024 MB |
| Max Database Used(Master) 79 MB Max Scratch Used(Master) 3 MB |
| Max Database Used(Workers) 1 MB Max Scratch Used(Workers) 4 MB |
| Sum Database Used(All) 82 MB Sum Scratch Used(All) 15 MB |
| CP Time (sec) = 0.500 Time = 10:30:52 |
| Elapsed Time (sec) = 3.000 Date = 06/12/2023 |
All-
September 25, 2023 at 10:57 am
Aniket
Ansys EmployeeThanks for adding this info, Daniel, in addition to the output that you have pasted, first line of the solver output (before legal notice) will indicate the license used to solve it:
What does it show?
-Aniket
September 22, 2023 at 8:00 pm
Mateus Cornelsen
SubscriberHi,
I ran into the same issue doing a very similar analysis. This error is due to the license in use not suporting the random vibration analysis, try switchting to a licensing level premium or enterprise. If you are using a student license it should have run, please check with support then.
You can check more about this on the ANTYPE command section on the Ansys Help
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/ans_cmd/Hlp_C_ANTYPE.html
- License Error
- Workbench not opening
- Workbench error
- how to open DesignModeler
- FlexNet Licensing – Not running
7626
4456
2955
1427
1322
