February 2, 2018 at 6:00 pm
DKY2Y
SubscriberI have just completed my impeller design using Vista CPD and created the cavitation simulation on Ansys CFX. However, I have carried out a transient simulation of the impeller using the following data:
Total Time= 5s
Time steps=0.01 s
Initial time=0 s
Output control
Backup:
Time step=100
Transient Results:
Time step interval=10
Does the spectrum results for the transient simulation look sensible as seen from the attached pictures? The data for the pump was obtained from a journal article where the pump has a high flow rate and high output pressure hence this explains why the transient results shows a high output
February 5, 2018 at 10:33 pm
Raef.Kobeissi
SubscriberI think a time step of 0.01s is not sufficient for such analysis, it needs to be 1e-3 minimum (also it depends on your mesh resolution).
Regards -
February 12, 2018 at 4:22 pm
DKY2Y
SubscriberHi, thank you for your assistance. I have changed my time step to 1e-3 seconds just yesterday. Does it look like it is converging properly as seen in the attached picture.
2656
2120
1347
1118
461
