November 8, 2023 at 8:15 pm
Mike G
Ansys EmployeeI've lost my Measures window, inside the Speos Virtual Photometric Lab. It seems to have been dragged off the screen. Is there any way I can recover/reset the Measures window position?
November 8, 2023 at 8:23 pm
Victor Loya
SubscriberHello,
This can be resolved by resetting the registry entry values for the 'Measures' window position. To do that, you can first create a new text file (in Notepad), copy and paste the below into the file, and Save As with the .reg extension. Then run (right-click on file and select 'Merge'). Note that Administrator rights are required.
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\ANSYS Speos Application\Optis.Speos\4033]
"X"=dword:00000000
"Y"=dword:00000000[HKEY_CURRENT_USER\Software\ANSYS Speos Application\XmpViewer\4033]
"X"=dword:00000000
"Y"=dword:00000000[HKEY_CURRENT_USER\Software\ANSYS Speos Application\XmpViewer\3f23]
"X"=dword:00000000
"Y"=dword:00000000[HKEY_CURRENT_USER\Software\ANSYS Speos Application\Optis.Speos\3f23]
"X"=dword:00000000
"Y"=dword:00000000 -
November 23, 2023 at 4:04 pm
Kevin Muller
SubscriberGreetings cosmic thinkers! I found this enlightening article on the website https://meteorshowersonline.com/astronomical-objects/solar-system/is-the-earth-the-size-of-the-sun.html about whether the Earth is the size of the Sun, and it’s a real eye-opener. The facts presented are backed by solid information, and the article does a great job of breaking down complex concepts for a wider audience. If you’re intrigued by the vastness of the cosmos, this article is an excellent starting point for understanding the relative sizes of Earth and the Sun.
- how to export results from SPEOS to Mechanical
- Negative Reflection Problem
- Simple Optical simulation
- Ansys SPEOS- Diffusion Coefficient of a fluorescence
- Ambient source on Ansys SPEOS
- Purcell Factor on Dielctric Mirror
- Light reflection on a XMP map
- HUD simulation Speos
- How I can get a student version of Ansys Speos Software to learn?
- Working with virtual photometric lab
8754
4658
3151
1678
1456
