Spheres Falling in Water using Macroscopic Particle Model (MPM) in Fluent
    • Gerald Gallagher
      I am attempting to simulate a sphere settling under gravity in a viscous fluid (water for now) using the Macroscopic Particle Method (MPM) in Fluent 2023 R1.
      I managed to set up a sphere falling in air by watching a good video posted on a YouTube channel mentioned in the CFD Online thread https://www.cfd-online.com/Forums/fluent/33104-macroscopic-particle-model-mpm.html:
      https://youtu.be/bGU62t9DDy0
      I tried to set up spheres falling in water with steps from another video posted on the same YouTube channel:
      https://youtu.be/920ajl_nV68
      However, the spheres either don't move or the behaviour is unphysical. Also, the continuity residuals are very large. The geometry I use is very similar; it is slightly simplified to be just a rectangular box without the reduction in size in the middle of the domain, but uses the same overall dimensions from the video. The mesh I am using has very similarly sized tetrahedral elements as well. I am following the steps as closely as possible, but I still cannot replicate the behaviour from the video.
      I should note that I had to replace the animation setup from the videos with the more current "scene" setup.
      Would anybody have any advice on this issue?
      Thanks!
      What material is the MPM particle defined as?
      • Gerald Gallagher
        Hi Rob,
        Thanks for your reply.
        I set the particle density to 1100 kg/m3 and diameter as 0.02 m in the MPM setup window as per the video. In the standard Fluent Materials section, "aluminium" is set as the material for "Solid" and I change the density to 1100 kg/m3 as per the video. The material "anthracite" is set as the material for "Inert Particle" and I change the density there to 1100 kg/m3 as per the video.
        It did seem strange that I should have to change the density in multiple places to the density of the particle. Is there anything that I am doing incorrectly?
        Thanks
      I've not used the model since it was a UDF function: it has a use but for dropping objects we tend to favour moving mesh or DEM now. I suspect the DPM part is because of the way the model works, no idea about why you'd need to alter the solid material.
