September 11, 2018 at 10:30 am
Prasanna
SubscriberI am trying to model spillway in 2D. The problem of floating point exception is always troubling me. Can anyone helpme in this regard.
September 11, 2018 at 10:39 am
Karthik R
AdministratorHello,
Please elaborate and provide some more details of your model. Please provide some screenshots as well as explain your boundary conditions. You might also want to take a look at the mesh statistics.
Floating point error generally occurs when the solver encounters a really small value in the denominator.
Another questions - does this happen right at the beginning or somewhere in the middle of a simulation?
Are you running a steady or unsteady problem?
In short, you might have to explain your problem better so we are able to help you.
Thank you.
Best Regards,
Karthik
September 11, 2018 at 10:52 am
September 11, 2018 at 10:57 am
September 11, 2018 at 11:06 am
seeta gunti
Ansys EmployeeHello Prasanna,
Thanks for the screen shots.
As I can see the screenshot and understand that k and epsilon are causing the divergence. I suggest to run with first order upwind scheme with lesser URFs. Can you try reducing the URFs of K & epsilon to 0.6 and run. If you still facing the divergence, you can still reduce to 0.5 or 0.4 and run the case. One more observation is reverse flow at the outlet. May be you can still extend your outlet and continue the run to avoid reverse flow at outlet. Kindly follow these two suggestions and let me know if you still faces the issue.
Seeta
September 11, 2018 at 11:56 am
Prasanna
SubscriberIf you can observe in the mesh, the boundary condition at the top most part of the geometry is also pressure outlet. can I understand that the reverse flow is because of not the left most outlet but it is rather because of the BC on the top. can you please provide clarification regarding this.
September 11, 2018 at 12:19 pm
September 11, 2018 at 2:02 pm
Ansys EmployeeCan you remesh and force a pave mesh onto the model? Don't use any edge sizing in GAMBIT and when you mesh the face select Pave (it looks to be defaulting to sub map). You probably also need to refine the mesh over the top of the weir: read up on VOF model and adaption in the documentation.
As an aside, I'd advise learning either DesignModeler or (ideally) SpaceClaim and ANSYS (Workbench) Meshing as they're the current tools used in industry.
September 11, 2018 at 2:32 pm
Prasanna
SubscriberThank you so much. I request you to suggest me any tutorial that helps me in creating the geometry in design modeller for spillway shape. -
September 11, 2018 at 2:43 pm
Karthik R
AdministratorHello,
This is our Youtube page with loads of learning material on 'How To'. I'd suggest you use these videos to get up to speed with DM and WB meshing tools.
https://www.youtube.com/channel/UCdymxOTZSP8RzRgFT8kpYpA
I hope this helps.
Best Regards,
Karthik
September 11, 2018 at 5:22 pm
Prasanna
SubscriberThank you karthik. Will surely use these. -
September 11, 2018 at 5:23 pm
Prasanna
September 15, 2018 at 10:19 am
September 17, 2018 at 10:32 am
Ansys EmployeeI suspect you need to reduce your timestep: the warning (for once) is fairly helpful. Depending on the flow velocity 0.01s may be too high.
September 18, 2018 at 1:52 am
Karthik R
AdministratorHello Prasanna,
please estimate your time step such that your Courant number does not exceed 1. This will ensure a stable solution. You might want to use the minimum grid size while estimating this time step size to be conservative.
please let us know what you find,
Best,
Karthik
September 19, 2018 at 2:50 pm
Prasanna
SubscriberHello,
Thank you very much for the suggestion. It worked out and the problem is solved
September 21, 2018 at 2:15 pm
September 21, 2018 at 3:18 pm
Prasanna
SubscriberHi,
I felt this information could add to clarify my doubt. The velocity provided at the inlet is 0.892 m/s. The inlet in the present case is taken as the height over the crest of the spillway.
2656
2120
1345
1118
461
