October 4, 2017 at 12:20 pm
pgl
Ansys Employee- Go to Design Tab, Select 'Split Curve' option. 2. Select the beam to be split. It will highlight the beam and its mid-point as well for reference. 3. Click the location on the beam to split.
October 4, 2017 at 2:39 pm
nselvara
Ansys EmployeeHow to split beams in Spaceclaim?
Trending discussions
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
Top Contributors
2646
2110
1337
1112
461
Top Rated Tags
