Discovery Import
Discovery Import
split faces joined during import
    • bonora.e
      Hi I'm trying to import a pivot with a split face but as soon as I import it into AIM, the 2 faces are joined I'm getting the issue with both parasolid and step I tried to play with some import parameter like "Decompose Disjoint Geometry" and "stich surfaces on import" with no changes
    • Naresh Patre
      Hello proxicad Instead of selecting "Import Geometry file" option in AIM workflow, select "Define new geometry" option. This will open a blank SpaceClaim session within AIM. Now go to Model - Import. Select STEP file format from the list of file formats and disable "Improve imported data" option as shown below. This will retain the face splits.
    • bonora.e
      thankyou Naresh, once again you guys saved my day
