November 17, 2020 at 2:17 pm
Milhm
SubscriberHi
I am working on spray cooling.I want to spray water in a compressible flow.The stagnation pressure is 4Mpa and static pressure is 0.696Mpa.I set operating pressure to zero and i enter 4Mpa and 0.696Mpa in pressure inlet boundary conditions.I enabled species transport.In materials for mixture template, i select ideal gas for density, mixing law for Cp and Sutherland Law for viscosity.I use pressure swirl atomizer.
At the beginning of injection i recieve this error:# Divergence detected in AMG for pressure coupled: protective actions enabled!
# Divergence detected in AMG for pressure coupled, temporarily solve with BCGSTAB!
Error: Divergence detected in AMG solver: pressure coupled
What should I do?what is wrong?
Regards
Milad
November 17, 2020 at 2:57 pm
November 17, 2020 at 2:58 pm
DrAmine
Ansys EmployeeAdd more information about your case and switch off injection at first. Run single phase!
- The topic ‘Spray Cooling Issue’ is closed to new replies.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Drop Test of a Water-Filled Tube
- Difference between “total pressure” and “absolute pressure”?
- obtaining pressure distribution by making points in ansys
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
8832
4658
3159
1688
1482
