November 11, 2019 at 7:37 am
Arvindkumar
SubscriberHello,
Combin14 is not possible with the non liner spring.
Hence i go with the Combin39 or Combin40.
I have attached the spring rate which i needed. I am trying to simulate the spring solid length behavior.
When i try to use the comment attached... i could not solve the problem when i give the Force as input. and the problem could be solved when i give the displacement as input.
Can any one help me ?
also is there is any method for creating gap elements? ie gap of 5mm should be there .. as soon as gap closes the contact should transfer the full load to other part??
November 11, 2019 at 1:30 pm
November 11, 2019 at 1:38 pm
Arvindkumar
SubscriberThanks Peter.
I have saw your post on Combin40. i will see the gap elements problem with that
et,_sid,39
keyopt,_sid,4,1
R,_sid,-12.1,-5000,-12,-656,-3,-164
RMORE, 0,0,10,10
November 12, 2019 at 2:51 am
SubscriberThere are many reasons why a solution will not complete. The spring definition is not enough information to say why the solution failed.
3275
2453
