Spring design
    • Mattia28
      Good evening,
      my problem is that i don't know how to design a 3D spring. I found some tutorials in which is used the function sweep , and it allowed to specify the number of turns , but in my version of the program ( Ansys student workbench 2019 R3 ) i can't find those options.
      Any suggestion ?
      Thank you
    • peteroznewman
      What kind of spring do you need to design?
      What are the requirements on the spring?
      • Free Length
      • Working Length Range
      • Working Force Range (from this and the previous a spring rate is calculated)
      • Space Envelope
      • Number of cycles of load it will see in a lifetime of product use.
    • Mattia28
      I don't need all this settings, i just need to design the geometry , with some data i know like the length, the number of coils, etc.
    • peteroznewman
      I use a Spring Design program to design coil springs, it's much faster and easier than using ANSYS.
    • Mattia28
      may i ask you how is it called?
    • peteroznewman
Viewing 5 reply threads
