November 21, 2023 at 2:04 pm
Alf
SubscriberI am trying to create a spring element in LSDYNA for a mass spring system. I have done this using a discrete element but I was wondering if there is a way to create the spring without using a discrete element. The reason being I am doing a study on stiffness damping (*DAMPING_PART_STIFFNESS) on a 1DOF system but this card cannot be applied to a discrete element.
November 27, 2023 at 7:10 am
Ushnish Basu
Ansys EmployeeYou can use a type 6 beam element, i.e. discrete beam element. Doing a google search for "ls dyna discrete beam" will get you to several online notes on how to use these elements.
November 27, 2023 at 1:27 pm
Alf
SubscriberI specifically cannot use a discrete element, whether that be a spring or a beam. I am wondering if there is a way to do it without using a discrete element.
- Explicit dynamics ERRORS
- turning simulation
- explicit dynamics
- Monte Carlo Simulation
- Error inside ANSYS LS Dyna: “An error occurred inside the SOLVER module: general error.”
8736
4658
3151
1678
1452
