March 31, 2023 at 1:50 pm
vijaykumar.chauhan
SubscriberHello Guys,
I have Rubber damper in my Model. Which is best approach for the Contact definition ?
- Spring joint with Damoing in all three Axis
- Bushing joint
April 5, 2023 at 6:11 am
Sahil Sura
Ansys EmployeeHello vijaykumar.chauhan,
It all depends on your application and the constraints you want to define.
Springs can be used when stiffness behavior in a specific direction is observed.
You can define the appropriate type of joint depending on your requirement for degrees of freedom like translational or rotational.
The following references may serve helpful in understanding the behavior of Springs and Bushing joints, and you can model the rubber damper by setting appropriate stiffness or damping.
Springs (ansys.com)
Bushing Joint (ansys.com)
Joint Types (ansys.com)
The video too might serve helpful in understanding different Kinematic constraints and how to define them in Ansys Mechanical-
Creating Kinematic Constraints Between Parts - Lesson 5 - ANSYS Innovation Courses
Hope this helps!
Thanks,
Sahil
https://forum.ansys.com/forums/topic/how-to-access-the-ansys-online-help/
https://forum.ansys.com/forums/topic/guidelines-for-posting-on-ansys-learning-forum/#latest-
April 5, 2023 at 10:50 am
vijaykumar.chauhan
SubscriberHello Sahil,
Thank you for the reply. Thing is i am using spring (with damping) in three direction to represent the damper. I also have structure damping of 0.02. I am using mode super position method to performe the harmonic analysis.
I have some question regards to that.
- which damping will be taken in to account in harmonic analysis ? (damping from spring or over all damping coeff.)
- do i need to use full analysis instead of mode super position ?
- which solver gives the better result for modal analysis ? full damped or reduced damp ?
Thank you in advance !!
3311
2469
