Spring mass model – control force applied
    • KUMARA
      As can be seen from the code, system is excited with a external force applied just at the instant 0.1s and again NO force is applied till 1s. During this time, as expected the system is oscillating at the natural frequency. But, then at 1s, I applied force on mass. This force is proportional to the displacement of the mass (like a spring, 0.5*error). But, the response is indicating that external force applied after 1s is acting as a damper not as a spring. Kindly help me how to interpret it accurately. I am using ANSYS 2020 R2.
    • Aniket
      Ansys staff can not download any files on the forum, so if you want to reach a larger audience to get answers from, please insert inline images describing your problem.
      -Aniket
    • peteroznewman
      !KUMARA RAJA E
      !Dynamic Analysis of SMMODEL
      /title,Spring Mass Controller force
      FINISH
      /Clear
      /PREP7
      ET,1,MASS21
      ET,2,COMBIN14
      R,1,0.001, , , , R,2,1,0,0, , ,50
      !Defining Material properties (Not needed for this problem though)
      MPTEMP,1,0
      MPDATA,EX,1,,210000
      MPDATA,DENS,1,,7800E-12
      MPDATA,PRXY,1,,0.3
      !Defining two nodes
      n,1,, n,2,50,
      ! MODEL Definition
      !Defining element attributes before creating elements
      TYPE, 1
      MAT, 1
      REAL, 1
      ESYS, 0
      !Creating mass element at node 2
      E,2, !Element 1 definition
      TYPE,2
      MAT,1
      REAL,2
      ESYS,0
      !Creating spring between node1 and node2
      E,1,2
      !Defining boundary condition (Fix node1)
      D,1,all,all
      ! Setup analysis
      /solu
      antype,transient
      trnopt,full
      time,0.001
      solve
      *DO,t,0.01,3,0.01 !Begining of DO loop
      TIME,t !Time at the end of load step
      *IF,t,LT,0.1,THEN, !Begining of IF condition
      F,2,FX,0
      *ELSEIF,t,EQ,0.1,THEN
      F,2,FX,2 ! A 2N force applied at 0.1s
      *ELSEIF,t,GT,0.1,AND,t,LT,1
      F,2,FX,0 ! Zero external force
      *ELSE
      *GET,error,NODE,2,U,X ! Obtain the deformation of node2
      F,2,FX,error*0.5 ! Applying the force
      *ENDIF !End of IF Condition
      SOLVE
      *ENDDO !END of DO loop
      !Post processing
      /post26
      nsol,3,2,u,x plvar,3
    • Ashish Khemka
      Hi Kumara,
      I tried modeling the problem you described at my end and I found the displacement of the mass to be correct.
      ANTYPE,TRANSIENT
      /prep7
      ET,1,COMBIN14,,,2
      ET,2,MASS21,,,4
      R,1,200            ! SPRING CONSTANT = 200
      R,2,.5             ! MASS = .5
      N,1
      N,2,1
      FILL
      E,1,2              ! SPRING ELEMENT (TYPE,1) AND K = 200 (REAL,1)
      TYPE,2
      REAL,2
      E,2                ! MASS ELEMENT (TYPE,2) AND MASS = .5 (REAL,3)
      D,1,ALL,0
      /solu
      trnopt,full
      *DIM,_loadvari32x,TABLE,4,1,1,TIME
      ! Time values
      *TAXIS,_loadvari32x(1),1,0.,8.e-002,0.1,2.1
      ! Load values
      _loadvari32x(1,1,1) = 0.
      _loadvari32x(2,1,1) = 0.
      _loadvari32x(3,1,1) = 0.
      _loadvari32x(4,1,1) = 0.
      *DIM,_loadvari32y,TABLE,5,1,1,TIME
      ! Time values
      *TAXIS,_loadvari32y(1),1,0.,8.e-002,0.1,1.1,2.1
      ! Load values
      _loadvari32y(1,1,1) = 0.
      _loadvari32y(2,1,1) = 0.
      _loadvari32y(3,1,1) = 100.
      _loadvari32y(4,1,1) = 150.
      _loadvari32y(5,1,1) = 200.
      f,2,fx,%_loadvari32y%
      autots,on                   ! User turned on automatic time stepping
      nsub,1000,1000,100,OFF
      time,0.1
      timint,on                  ! Turn on time integration effects
      outres,erase
      outres,all,none
      outres,nsol,all,
      outres,rsol,all
      outres,eangl,all
      outres,etmp,all
      outres,veng,all
      outres,strs,all,
      outres,epel,all,
      outres,eppl,all,
      outres,cont,all,
      outres,v,all,
      outres,a,all,
      solve
      fdel,2,fx
      time,1.1
      outres,erase
      outres,all,none
      outres,nsol,all,
      outres,rsol,all
      outres,eangl,all
      outres,etmp,all
      outres,veng,all
      outres,strs,all,
      outres,epel,all,
      outres,eppl,all,
      outres,cont,all,
      outres,v,all,
      outres,a,all,
      solve
      time,2.1
      outres,erase
      outres,all,none
      outres,nsol,all,
      outres,rsol,all
      outres,eangl,all
      outres,etmp,all
      outres,veng,all
      outres,strs,all,
      outres,epel,all,
      outres,eppl,all,
      outres,cont,all,
      outres,v,all,
      outres,a,all,
      solve
      Ashish Khemka
      • 154010010
        Dear Ashish,
        Thanks for your response. I want to apply a force that is a  function of the instantaneous mass displacement, but, I couldn't find such a force defined in your code. I have copied my code below.
        To put it in equations, I have m*x\ddot + k*x = f(x,t)  not  m*x\ddot + k*x = f(t).
        I understand that applying a state dependent force requires to be able tap into output at every step and extract displacement/velocity at every instant and redefine the force on nodes depending on these vales. I thought my code should do the same, but, as mentioned in my previous posts results are not as expected. Please help me understand the issue.
        FINISH
        /Clear
        /PREP7
        ET,1,MASS21
        ET,2,COMBIN14
        R,1,0.001, , , , ,
        R,2,1,0,0, , ,50,
        MPTEMP,1,0
        MPDATA,EX,1,,210000
        MPDATA,PRXY,1,,0.3
        !Defining two nodes
        n,1,,,
        n,2,50,,
        ! MODEL Definition
        TYPE, 1
        MAT,  1
        REAL, 1
        ESYS, 0
        TYPE,2
        MAT,1
        REAL,2
        ESYS,0
        E,1,2,
        D,1,all,all
        ! Setup analysis
        /solu
        antype,transient
        trnopt,full
        time,0.001
        solve
                    F,2,FX,0
                *ELSE
            SOLVE
        !Post processing
        /post26
        nsol,3,2,u,x,
        plvar,3
        Kumara
Viewing 3 reply threads
