January 1, 2023 at 8:02 pm
Chun-Wei Tsai
SubscriberHello!
I am currently trying to build a model of a square fuel tank (will start from 2D if success will move to 3D), I am wondering what are the steps to build the model that can simulate a square fuel tank contains half jet fuel vapour and half jet fuel liquid in a freezing temperature (approximately -70 degree C). The result will be looking at the temperature profile over times. I am thinking about transient thermal in the workbench but not sure what are the general procedure.
Thank you very much!
January 2, 2023 at 5:25 am
Nikhil Narale
Ansys EmployeeHello,
"contains half jet fuel vapour and half jet fuel liquid"
Can you please elaborate on this, perhaps by sharing some illustrations?
I would recommend you to try this out in the Ansys Fluent.
Check out this link:
Chapter 20: Using the VOF Model (ansys.com)
Chapter 19: Modeling Evaporating Liquid Spray (ansys.com)
If you are not able to access the link, refer to this forum discussion:
Thanks!
Nikhil
January 2, 2023 at 5:34 am
SRP
SubscriberHi,
In order to carry out the simulation, I advise using the multiphase model (VOF).
For more details about the multiphase, please refer to the theory guide: Chapter 14: Multiphase Flows (ansys.com)
Also, please refer to the user's guide: Chapter 22: Modeling Multiphase Flows (ansys.com)
Hope you find this useful
Thank you
January 2, 2023 at 6:08 pm
Chun-Wei Tsai
SubscriberSorry if I didn't make the question clear enough, I am going to build a simple square model with fuel already inside. I want to place the model in a very cool condition (about -70 degree celcius) for a certain time, and I want to see the temperature contour plot and observe that how long does it take for the fuel inside the square tank to reach a certain temperature.
January 3, 2023 at 3:21 pm
Ansys EmployeeOK, so the multiphase part of the examples is OK, you need to patch the fuel level. Note, you'll need a vent otherwise the whole system is going to get interesting unless the gas is compressible! Don't forget you'll need density to vary with temperature & turn gravity on if you want to see natural convection.
2656
2120
1347
1118
461
