March 31, 2023 at 1:56 pm
April 3, 2023 at 2:56 am
Atharv Joshi
Forum ModeratorHello joe jackson ,
The sketch plane gets created on the center of the selected facet when using such STL files.
If it's a surface, then it gets created at the center of the surface. You can use the "Move gird" option to move the gride center as per your requirement.
Thanks and Regards
April 3, 2023 at 9:29 am
Atharv Joshi
Forum ModeratorHi joe jackson ,
I have created a short video to demonstrate the move operations on the grid.
Please go through these tutorials that will help you working with mesh/STL bodies Discovery SpaceClaim: 3D Printing Prep & STL/Facet Editing – Ansys Knowledge
Let me know if this helps and if you have any questions.
🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
- How to work with STL file?
- section plane
- material properties
- Coordinates orientation
7646
4468
2957
1427
1322
