Squeeze a 3D cylinder
    • Seyyed Mahmoud Mousavi
      Hi!
      My initial geometry in Fluent is a cylinder with a length of L = 40mm and an R = 2mm cross-sectional radius. I need to deform the cylinder radius (1mm < R < 3mm) in time in my transient simulation in Fluent (squeeze or outstretch the cylinder).
      Could anyone please help me with this? Please don't simply say to use a udf; I have searched for it but still couldn't get/find a similar udf file so I can modify it to fit my purpose; please be more specific in your answer like which functions I should use in the udf.
      Thanks!
      Start here, https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_udf/flu_udf_DynamicMeshDEFINE.html  Which macro do you think would be best?
        Dear Rob!
        The link is directing me to the customer portal page and asks me to register there. I don't have, however, to register there. What can I do? I have the Fluent user manuals pdf or UDF manual pdf (2022 R2). Are you trying to refer to me in those pdf files? Can I ask which section of those files?
        Thank you!
      If you click on Help in the solver you'll get a browser up. Then copy the link into that browser. The solver adds a cookie/token/biscuit to bypass the log in process.
