October 6, 2023 at 5:04 pm
Frederico Ricca
SubscriberHello, I'm a master's student currently working on my thesis. My job is to find a numerical tool capable of simulating the squeeze flow of an adhesive fluid when it is pressed by a moving substrate against a fixed substrate. I know that the speed could be something like 0.1 mm/s. The initial thickness should be 2 mm and the final thickness should be 1 mm. My question is, do I need to run an FSI simulation or can I just use fluent? If so, what steps will the solution take? What could be the boundary conditions? Thank you!
October 9, 2023 at 11:03 am
Forum ModeratorAssuming the two plates aren't deformed by the fluid then Fluent with VOF will work. You will need moving mesh to simulate the squeezing effect.
- legend min and max
- Ensight hot iron palette from an image
- Streamlines in EnSight using MRI data
- Import MRI data into Ensight
- FLUENT APPLICATIION ERROR
- Total Surface Heat Flux Calculation in Fluent
- Difference between “total pressure” and “absolute pressure”?
- Drop Test of a Water-Filled Tube
- Minimum Orthogonal Quality Less than 0.01 For Transonic Airfoil Flow Analysis
- obtaining pressure distribution by making points in ansys
8808
4658
3153
1680
1470
