Stability analysis
    • Deepesh
      How do I perform stability analysis on a shaft ? (Ansys workbench)
      Is stability analysis just getting a time decay graph?
      If someone can explain what exactly is Stability analysis ?
      Thanks
    • peteroznewman
      In other posts, you were given links to the Rotodynamic Analysis Guide. Read section 6.7.2
      https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v195/ans_rot/Hlp_G_ROTCAMPDIAGS.html
       6.7.2. Check the Stability and Whirl of Each Mode
      Forward (FW), and backward (BW) whirls, and unstable frequencies are identified in the Campbell diagram analysis. These characteristics appear in the Campbell diagram graphic legend generated by the PLCAMP command. Forward and backward whirls are printed out in the table generated by the PRCAMP command, as shown below.
      What did you find when you searched Google?
    • Deepesh
      Sir, its asking for some customer login details or showing. As of now, login details aren't with me. Can you provide some other link of Ansys help that could open without logging in??
    • peteroznewman
Viewing 3 reply threads
