Stabilization error for two-phase flow simulation
    • abhnv_01
      I am trying to simulate a heat pipe in (3D) which has three sections:
      Evaporator - Constant heat flux (boundary conditions)
      Condensor - Constant temperature (boundary conditions)
      Adiabatic section - Zero heat flux (boundary conditions)
      I am using VOF multiphase model -> Evaporation - condensation model -> Lee model.
      Transient simulation with gravity and implicit body force formulation.
      Time step size = 0.0001 (1E-04).
      The simulation runs well for about 10-12 seconds of flow time but then it stops due to this error
      "Divergence detected in AMG solver: pressure correction        Stabilizing temperature to enhance linear solver robustness.
              Stabilizing temperature using GMRES to enhance linear solver robustness.
      Divergence detected in AMG solver: temperature
      Divergence detected in AMG solver: pressure correction"
       Even though the simulation was running well for 10-12 seconds (100,000 time steps). What can be the possible reason for this error?
    • SRP
      This error message is an indication that equation is diverging. The most likely cause is that the under-relaxation factor (URF) for that equation is too large. Reduce the URF by 10%.
      Thank you.
    • abhnv_01
      I had already changed the URFs.
      Following are the URFs I have kept in my case:
      Pressure - 0.5
      Density - 1
      Body forces - 1
      Momentum - 0.2
      Vaporazation of mass - 1
      Energy - 0.8
      Phase change and VOF currently don't always work well. If you look at the flow field a bit before divergence what is happening?
Viewing 3 reply threads
