August 27, 2018 at 10:33 pm
danielc358
SubscriberHi good night!!!!
I was in need of a bibiliography that teaches how to get a stable mesh with Ansys, does anyone know of a book that teaches you to get stable meshes with Ansys?
Daniel
August 28, 2018 at 12:11 am
SubscriberHi Daniel,
What do you mean by a "stable mesh"?
August 28, 2018 at 1:36 am
danielc358
SubscriberHi Peter, good evening !!!!
I wanted a bibiliografica reference or a tutorial that taught the steps to obtain a good mesh.
Daniel
August 28, 2018 at 10:09 am
Ansys EmployeeWhich solver are you wanting to use? The mesh requirements for Mechanical are very different to Fluent, and different again to the Explicit or Maxwell.
August 28, 2018 at 11:55 am
danielc358
SubscriberHi Rwoolhou, good morning !!!!
The simulations will be done in both Mechanical and Fluent
Is there any tutorial that teaches you how to get a good mesh?
Daniel
August 28, 2018 at 12:49 pm
Ansys EmployeeOK, thanks for clarifying.
First off, the mesh requirements differ between the codes so you shouldn't use a Mech mesh for CFD and vice versa. There are tutorials covering meshing (and requirements) but I'm not sure what is available in the public domain: the ones I know of are on the ANSYS Customer Portal and Learning Hub and aren't accessible to students.
Having said that, put "ansys meshing tutorial" without the " into YouTube and you'll see several available. I also recommend sketching out the geometry before you start are you want to cluster mesh in regions of high gradient in both CFD & Mechanical: when you start out that will require some thinking! Check the Cornell MOOC too https://www.edx.org/course/a-hands-on-introduction-to-engineering-simulations
August 28, 2018 at 5:56 pm
DrAmine
Ansys EmployeeJust to add to the comments of Mr. rwoolhou please have a look into:
https://www.nafems.org/join/resources/cfd_guidance/
https://www.nafems.org/join/resources/knowledgebase/001/
https://www.ercoftac.org/publications/ercoftac_best_practice_guidelines/
August 31, 2018 at 10:11 am
Keyur Kanade
Ansys EmployeeJust one more link for how to videos.
https://www.youtube.com/user/ANSYSHowToVideos/videos
Keyur
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2522
2064
1279
1094
456
